Error 1073807202 occurred at Property Node (arg 1) in VISA Configure
I am working with the 30-day evaluation version of LabVIEW
(Version 9.0 32-bit).  I am attempting to perform the serial loopback test
described in NI's Developer Zone Tutorial, executing Basic Serial Read and
Write.vi.  When I click the Run arrow a dialog box appears with the
following legend:
"Error 1073807202 occurred at Property Node (arg 1) in VISA Configure
Serial Port (Instr).vi>Basic Serial Read and Write.vi.  LabVIEW: VISA or
code library could not be located.  ...required drive not installed..."
I can find the "smplserl.vi" driver in the /examples folder on my PC.
What's wrong?
(4,734 Views)
Did you do a search for that error? Install NI-VISA.
(4,720 Views)
