Error 1000 in a statechart
Hello, I'm working with a statechart module in LabVIEW, there is a program made by other persone and I have to know how it works. I made a little change and when I want to generate the code I have a error 1000. I want to know why.
Hope you can help me. Thank you
(3,230 Views)
This is an unusual error.  It suggests that something might be open or perhaps running when you are trying to generate your statechart code.
When I generate new statechart code, I usually do so from a freshly opened LabVIEW project so that I know nothing is running and ONLY the statechart code is open.
If that doesn't work for you, I'd suggest posting your code if possible.
Patrick Allen: FunctionalityUnlimited.ca
(3,211 Views)
Thank you for the answer. I do that, there is just the statechart opened but it don't work. I don't know how it works exactly, I'm new in this.
(3,206 Views)
Unfortunately none of your VIs were attached with your statechart code, so I can't really see what's wrong.
If you can attach the 5 missing VIs, I should be able to quickly try making a change and rebuilding the statechart to see if I get the same errors.
Which version of LabVIEW are you using?
(3,192 Views)
I think that it is a problem with my program because I did it in another computer and it worked. Thank you very much.
(3,171 Views)
