‎08-08-2017 04:11 AM
Hi!
So 2 stations just got Error 0x80040311 -2147220719 after working well for a several years, as far as my Google Fu works i can say it's a rare error, i could only find 2 threads on it, the last 2 years ago.
Is there much else i can do but reinstall DAQmx and possibly reset MAX db?
/Y
‎08-09-2017 08:50 AM
Hi Yamaeda,
Without more information it would be difficult for any of our forum users to say the exact cause of error. Reinstalling DAQmx would be a good start just in case its corrupted. Also your message suggests that you have been running the programme for a long time (several years) have you tried restarting LabVIEW. If this doesn't solve your issue it would be helpful to know details such as:
-What version of LabVIEW are you using
-What hardware are you using
-What changed on your system recently e.g a windows update or did you download any new software (even if its not LabVIEW related)
-Are you using any third party hardware or drivers
Kind Regards,
Bernadine
‎08-10-2017 09:36 AM
I seem to have solved it.
They haven't been constantly running for years, they're typically up for a week at a time, but the program itself is old, the latest version is ~1 year old so it's not a recent code change that's the issue.
What seems to have happened is a IT department update which created a VISA port conflict in MAX that then disabled a COM port. The error message in the program was as mentioned.
I've just fixed it over a remote desktop and on one computer i could access MAX and simply solve the conflict. On the other one the MAX db was corrupted so bad i couldn't access MAX-reset but had to use the external ResetMaxDb. After a MAX import of Tasks it seems to have solved the issue.
/Y
