Envelope of an waveform is in XY graph and need it in waveform graph
Dear aeastet,
Am very sorry. I have to vacate right now Smiley Sad and i will be back in another 5 hours in the morning. Smiley Happy Please post the changes and i will eagerly have a look at it.
Thanks a lot,
Mathan
Message 21 of 25
(1,293 Views)
OK I got it to work. I am not sure if you need to have the 5% as a fixed value. I used 6% for the value and it found the correct spot on the curve. If you are set on 5% then we will have to filter that data because it looks like there is on spot on the curve that meets the 5% rising curve requirement. I tried it on the other data and it seemed to work as well. This will just mean that you may pick your point a little later than before as you are a little less sensitive to change.
Tim
GHSP
Message 22 of 25
(1,283 Views)
Dear aeastet,
Thanks a lot for looking into this. But according to this measurement as in the picture above, i need to measure exactly 5% rising edge to calculate t1. As you said, there is a spot on the curve that meets the 5% rising curve. But that's the not correct one and we need to measure the one as like in the figure.
Thanks again,
Mathan
Message 23 of 25
(1,273 Views)
OK in this version I changed how many sample the vi is using to see the change to a rising signal. So it works for 5%.
Tim
GHSP
Message 24 of 25
(1,257 Views)
Dear aeastet,
There is another one interesting waveform measurement, this time its bit challenging. I have started a new thread to avoid confusion. Can you please help me out here.
Thanks much,
Mathan
Message 25 of 25
(1,220 Views)
