Envelope of an waveform is in XY graph and need it in waveform graph
From the other threads here and here, i got excellent support from David and Thomas. Thanks all. Smiley Happy
The envelope of the signal coming out as per David's example is in form of XY Graph. But as per Thomas' example, i need waveform graphuntitled1.PNG in this format so that i can find out some of the rising and falling edge values in the waveform. So kindly suggest me how to handle this conversion. Thanks.
Mathan
Message 1 of 25
(5,653 Views)
How about something like this
Tim
GHSP
Message 2 of 25
(5,635 Views)
This one impliments it all
Tim
GHSP
Message 3 of 25
(5,630 Views)
I cleaned the diagram on this one and made it more simple
Tim
GHSP
Message 4 of 25
(5,621 Views)
Dear aeastet,
All i can say is simply superb and very perfect.... Thanks very much.... Smiley Happy
Message 5 of 25
(5,604 Views)
Glad I could help.
Tim
GHSP
Message 6 of 25
(5,577 Views)
Dear aeastet,
Thanks a lot for all your help. I do need some more favor.
I now replaced all the previous drivers for my Tektronix oscilloscope with the newer ones and now instead of amplitude versus number of samples, the output from the oscilloscope graph will be amplitude versus time (directly). In this case, what i need to give to the for loop input (you gave 30 in the previous case). David in the other thread mentioned it was the number of Zero crossings in the waveform(Hope he will watch this thread also and will do some favor for me). I didn't understand that term. Kindly can you explain me the working principle of the program. Thanks a lot again for all your inputs.
[Edit: I unmarked it from solution, since i assume that a solved thread will only get less inputs. I will mark it as solve again when i get my problem solved. Thanks]
Mathan
Message Edited by Mathan on 12-07-2009 07:44 AM
Message 7 of 25
(5,516 Views)
Attached is the modified program with the new driver's output in amplitude vs time graph.
Message 8 of 25
(5,511 Views)
So if I am understanding what you want here. You need to plot the output of the ocilliscope directly to the graph. So you need the graph to plot Frequency vs time. Is this correct? If you want to calculate the envelope of the waveform than there will always be some delay to calculate the peak and minimum for the trace. I am sure that we can get close to this but I just want to make sure that I understand the request.
Tim
GHSP
Message 9 of 25
(5,502 Views)
Are you going to know the frequency of the waveform when you start taking the data?
Tim
GHSP
Message 10 of 25
(5,501 Views)
