Entry Point Not Found
Hi all,
I have recently installed a run-time engine ver 7.0 on my pc which is running on Winnt 4.0 Workstation. After which I have tried to run the executable program amp.exe but I encountered this error.
amp.exe-Entry Point Not Found
"The procedure entry point GetCVT windowshandler for Curr Thread could not be located in dynamic link library cvirt.dll."
May I know what is the cause of the problem & how can i resolve it? Thanks!
(4,189 Views)
aiya 写:
Hi all,
I think your problem with related to you downloaded the run time engine versions,or needs in addition other run time engine,sorry! my english is not good,i speak chinese .
Best Regards,
Kim
(4,176 Views)
Hi aiya,
It looks like the cvirt.dll was corrupted upon installation. This has been documented as occuring with WinNT in the past and a reinstall over the first install has shown to fix the issue. The LabVIEW RTE can be searched for and downloaded from the ni.com Drivers and Updates page.
Hope this helps!
Kileen
(4,162 Views)
Hi Kileen,
Thank you very much for your help! I manage to reinstall & it works! 🙂
aiya
(4,156 Views)
That's awesome! Thanks for the follow-up on that and I'm glad things are working again. 🙂
Kileen
(4,143 Views)
