Enter Key action in the Table control
     I have a Table control (Labview 2013 SP1)   and have made the following assumption....
1.) When I modify the text in a cell and press the "Enter/Return" key I will get a "table change" event
What is really happening is that the position in the cell moves down one row and I do not see a table change event. However when I modify a cell and use the "tab key" everything works that way I want it to. So is there a way to have the "Enter/Return" key function just like the "Tab Key" in a table control?
I am trying to avoid having to trap a "key down state" in the table and figure out what key way pressed and/or compare the old and new values to update the edit position.
Kaspar
(5,090 Views)
   I am getting a "Table change" event when I press the enter key, however the "Edit position" property node is set to (-2,-2) which is not the cell location that I edited
Kaspar
(5,072 Views)
If you want the edited cell:
I'm not sure what else you're asking.
Jim
(5,061 Views)
Check your LabVIEW Environment Options; the option 'End text entry with Enter key' is normally not checked.  This default behavior places a CR/LF in your control, rather than ending the entry.
(5,055 Views)
   I will check the box in the environemnts setting just to see how it works. However changing the environment settings will apply to everything I do and it will also not be part of the code for this specific project. Is there a way to programtically do this?
Kaspar
(5,050 Views)
  I decided not to use this option (if it worked) because it would affect every project and/or code that I worked on. This would be difficult to have others being able to work and/or support the code
Kaspar
(5,039 Views)
