I2C MMA8452
I m using MyRIO and I try to connect on the I2C accelerometer MMA8452.
I made the connections to the board but i didint get good results, I can comunicate but the rezult is like a noise.
This example is from ADXL345 and when i change the register adress and still bad information.
And one more problem i dont all the names from the register map.
Corciova Florin
(3,209 Views)
Hi Corciova,
If you could provide a little more information about your setup that would be good. Have you made sure that the configuration for your device is correct?
Also I think that I have found the register map for your device on page 41 http://www.freescale.com/files/sensors/doc/data_sheet/MMA8452Q.pdf.
Scott B.
AE NI
(3,172 Views)
