Energy Metering Labview
I want to make energy meter.Current and voltage values are continuously coming form voltage and current sensor.These are multiplied with east other and time and that value is stored and continuously added to the previous values.This will show energy consumption.Please help me.I will be thankful to you.
Message 1 of 8
(4,384 Views)
How is it going so far? What have you managed to get done, and what are you stuck with?
It sounds like you have a solid plan, so go ahead and code it! LabVIEW can acquire data in a lot of different ways, so if you're having a specific difficulty, let the forum know and people will be happy to help you.
GCentral
Message 2 of 8
(4,367 Views)
will you use PLC?
let me know about that.
thanks,
asif
Message 3 of 8
(4,314 Views)
Are there two separate meters?  Using a single meter, the measurements will be done in series and not parallel.  If using two meters, then consider this.  Realize that when current is measured, that the meters actually place a current sensing resistor (typically <=5ohms) in the path and measure the voltage across them.  That added current sense resistor could end up affecting your power measurement calculations.  If the load is inductive or capacitive, then it will also create an AC component as well as a charging or discharging feature during transitions.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 4 of 8
(4,310 Views)
Measuring volts and current and multiplying gives you VA (Apparent Power), not Watts (True Power).
=== Engineer Ambiguously ===
Message 5 of 8
(4,283 Views)
I want to multiply it with time and then add it continuously.?
Message 6 of 8
(4,267 Views)
Write out how you would do it with a flowchart or with some pseudocode.  Then you should be able to easily translate that to LabVIEW logic.
Message 7 of 8
(4,264 Views)
That will give you Voltamp Hours (Apparent power usage) not Watt Hours (Real power usage).
You really need a proper wattmeter to measure energy usage.
Message 8 of 8
(4,248 Views)
