Encryption using Fast Fourier Transform
@RTSLVU wrote:
Sheese where were you guys 6 years ago when I spent 10 minutes writing this to answer a question on encryption using LabVIEW? 😛
Found it and posted a quick followup. 😄
Message 11 of 30
(2,739 Views)
Can you post
@altenbach wrote:
Yes, we need to protect from zero-length keys, but the math is especially simple (in=out) in that case 😄
Here's what I might do. The loop can even be parallelized, but I doubt it would make a big difference. (Same code for encryption and decryption.)
Can you please share this VI? This may seem ridiculous (then again, LabVIEW is a truly ridiculous thing), but I've spent about 30 minutes trying to figure out what on earth that array function is. God forbid things be named or otherwise findable.
Message 12 of 30
(2,029 Views)
I think the function is
Message 13 of 30
(2,012 Views)
If you turn on text in the palette...
...you'll see the function names:
You don't need the name; you can match the function from the palette by how it looks.
Granted, it does help to have 25 years of experience. 😁
It doesn't help that the appearance changes over versions and when function inputs or options change...
Message 14 of 30
(1,984 Views)
Yes, I'm aware of how the palettes work. The problem is, that block doesn't have the same icon in the palette as it does on that vi, making it absolutely, completely less than useless.
So, yeah. Ridiculous, like I said.
Message 15 of 30
(1,962 Views)
Sorry I have trouble taking a person's opinion of LabVIEW seriously that calls nodes on the palette "blocks". Calling them "blocks" is ridiculous. VIs. Functions. Even primitives. Not "blocks".
Bill
CLD
(Mid-Level minion.)
Message 16 of 30
(1,960 Views)
When I started learning LabVIEW, I also didn't notice that many of the Array functions are written to deal not only with 1D arrays (where they have one input for the index) but with 2-D, 3-D, ...n-D arrays just by "pulling down" the lower edge of the function to "spawn" another "Index Input".  Indeed, one of my first posts on this Forum involved a (maybe 3-)D array, and I'd actually wired "0", "1", and "2" into the three left-hand Index inputs.  Some kind soul (may have even been @Altenbach) pointed out to me I could save a lot of time by leaving them "unwired", whereupon they take up the sensible "default" assignments 0, 1, 2, ...
So this "logical feature" that allows, say, Index Array, to work for arrays of any dimension in an "intuitive" manner is a feature, sensible, and not a "bug".
Message 17 of 30
(1,953 Views)
  • Chances are that a "real" LabVIEW programmer does not try to recreate code given a picture. That would be ridiculous!
  • Chances are that a "real" LabVIEW programmer uses Quick Drop and never even looks at the palette.
  • A palette that would contain pictures of every single polymorphic alternative of each function (limited to e.g. 3D max. dimensions) would be 10x lager, making finding any specific function 100x harder. Nobody wants that! 😮 (Palette bloat is a serious problem and I tend not to install even e.g. OpenG tools.)
I post code pictures if the code is simple and fully visible (there is even a note that the other case is empty!). This makes it version invariant and students learn something when trying to recreate it from scratch (hint, hint!).
I strongly recommend not to use AI for now. For example Google thinks that this function is "index array" instead of "reshape array". 😮
Message 18 of 30
(1,935 Views)
And here's the block diagram, containing 0 blocks...
Message 19 of 30
(1,920 Views)
I mean, it is called the "block diagram" 😉
Message 20 of 30
(1,919 Views)
