02-21-2012 09:29 AM
Hello Everyone,
I just wanted to ask if there is a pre-built VI that measures the position using counters that looks something similar like this.
Marwan
02-22-2012 10:01 AM
I'm not sure what devices you are using to measure the angular encoder, but if you're using DAQ devices then you might try this VI:
Open the example finder (Help --> Find Examples). Then navigate to:
Hardware Input and Output --> DAQmx --> Counter Measurements --> Position --> Measure Angular Position.vi
02-22-2012 11:09 AM
I cannot find it. Can't you give me the link?
Thanks.
02-22-2012 11:48 AM
It's not a link that's hosted on the web, it comes with a LabVIEW install. Open up LabVIEW and go to Help --> Find Examples, and follow the steps from there.
If you don't have NI-DAQmx installed, then you won't be able to find it in the example finder. Go to ni.com/support --> NI-DAQmx to get DAQmx.
