Enabled State operation of a control?
Is there a way (how) to programmatically alter the Enabled State of a control?
I would like to 'Gray out' controls that are inactive to the user under some conditions and make them available when they are active.  This requires dynamically altering the enabled state of the control.
(3,000 Views)
Use the property node of that control - 'Disabled'
Regards
Raja
(2,992 Views)
Accepted by topic author TE88
TE88,
Attached you will find a screenshot on how setting properties on controls and indicators. You have to use the VI-Server classes.
HTH
Joachim
(2,991 Views)
