Elliptic integral in LV a different result
Hi All,
In LabVIEW I found a different result for the elliptic integral of first kind.
For example if I put input k= 0.994673
LV give a result K(k)= 4.01
All other routines, this is an example:
https://keisan.casio.com/exec/system/1180573454
Give a result K(k)= 3.6656...
Someone could explain me why?
What is the correct result?
(1,544 Views)
Hi Mal,
maybe you should also attach the VI you are using to calculate the integral…
(Many of us prefer older LabVIEW versions, so you might "Save for Previous" to provide your VI for LV2019 or so in case you use a recent LabVIEW version.)
(1,512 Views)
Attached code.
Best regards
(1,487 Views)
Accepted by Mal123
It seems LabVIEW defines the k slightly differently.
You get the correct values if you square the input as follows.
I am not familiar enough with the details of the parameter conventions or who is more "right". 😄
(1,457 Views)
LabVIEW probably should have called the input terminal "m" instead of "k". (see here)
Note that Matlab also uses "m" (i.e. k²) as input, but names it correctly. (details).
(1,450 Views)
Dear Altenbach,
Thank you very much, I was going crazy,
I was deceived by the fact that the second kind result was about the same number rounded.
Best regards
(1,419 Views)
