Elements in Cluster to Array in Cluster (generic)
Is there an easy and generic way to combine multiple clusters (containing the same datatypes (1 int and 2 strings)) to get a cluster containing arrays of the same datatypes (1Array of int and 2 Array of strings)?
The Background is that I recieve multiple measurement-clusters with measurement values (int) as well as the name of the measurement (string) and the unit (string) and want to end up with arrays inside a cluster containing the infos for each measurement at the same index of the array.
Best,
LabEti
(3,242 Views)
Hi Eti,
convert both input clusters to arrays, then bundle them…
(3,238 Views)
Unfortunately that didn't solve my problem.
I would like to get something like this (picture) in the end where the number of input clusters would be variable.
Best
LabEti
(3,226 Views)
Accepted by LabEti
whenever you need to handle several objects of the same datatype you should build an array of them:
(3,221 Views)
Isn't there a built in function for that nowadays? (since 2014 or something)
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,204 Views)
Index and bundle exists!  I would caution the OP to use a variant rather than a string.
"Should be" isn't "Is" -Jay
(3,171 Views)
