취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
Editing Listbox Run Time
Help says you can edit the cells but it does not work on my system.  Running LV 8.0.  The cells will not go into edit mode even with Editable Cells enabled.
Matt
Editing Listbox and Tree Control Cells at Run Time
Complete the following steps to edit cells in a listbox or tree control at run time.
  1. Right-click the listbox or tree control and select Editable Cells from the shortcut menu to allow users to edit cells at run time. You also can use the Allow Editing Cells property to programmatically allow users to edit cells in a single-column listbox, multicolumn listbox, or tree control.
  2. At run time, click the cell text you want to edit, and click it a second time after a short pause.
  3. Enter the text you want.
Use the Edit Cell event to handle the event that a user changes text in the cell of a single-column listbox, multicolumn listbox, or tree control.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
0 포인트
1/9 메시지
5,800 조회수
I have no problem editing Listbox cells on my system. Your vi works : as requested, it opens the message window when switching to edit mode.
Chilly Charly    (aka CC)
2/9 메시지
5,790 조회수
CC,
I am runing 8.0 and have not installed the patch to 8.0.1.  I checked the readme for the patch and there was nothing about the patch fixing this issue.  So, what version are you running?
Matt
Matthew Fitzsimons
0 포인트
3/9 메시지
5,778 조회수
It now works on a different PC that does have the 8.0.1 applied.  Seems that the patch is the fix.
Matt
Message Edited by mfitzsimons on 05-15-2006 10:26 AM
Matthew Fitzsimons
0 포인트
4/9 메시지
5,769 조회수
Matt
Just tried your VI in version 8.0 and its fine.
David
5/9 메시지
5,766 조회수
David,
Now this is scarry!  Some sort of PC dependency or corruption with my install.  The multicolumn listbox did cause LabVIEW to crash.  Maybe the issue is with my install.  Any ideas on if running LV repair will fix issues with LV 8.0?  The PC does have LV 7.1 and 8.0 on it.
Matt
Matthew Fitzsimons
0 포인트
6/9 메시지
5,764 조회수
Matt
Sorry. Not had to do any labview install repairs so I can't speak from experience. I agree that might be you next step. But before you do that...
Does rebuilding your vi always behave the same way?
I built a LV8 vi and tested it here. Does it work on your PC?
David
ps: Forgot to default the listbox
Message Edited by David Crawford on 05-15-2006 04:41 PM
7/9 메시지
5,761 조회수
It works fine at work.  I will have to try your version at home tonight (aka the problem PC)
Matt
Matthew Fitzsimons
0 포인트
8/9 메시지
5,753 조회수
Seems that LabVIEW has healed itself.  Everything is working fine today.  Looks like it just needed a reboot.
Thanks!
Matthew Fitzsimons
0 포인트
9/9 메시지
5,735 조회수
