Edit dialog box expressVI
Hi, I need to replicate the expressVI "Mask and Limit Testing". In runtime, the user can press a button and the same panel than the expessVI should be opened.
A couple of questions:
1) Is it possible to edit the Configuration Dialog Box of this express VI? I can find just the SubVI and SourceVI, but not Configuartion Dialog Box. Whether I cannot edit it, is there any chance to use this dialog box programmatically? Creating an  instance?
2) Writing code, how can I replicate the same functionality? I did it using the method "Map coord to XY", but it is not exactly what I want.
Thanks a lot.
(2,866 Views)
Is this what you're looking for: Create or Edit Express VI Dialog Box.
(2,855 Views)
I installed the Express VI development Toolkit. But when I run it, it appears completely empty (see picture).
Then it cannot help me.
(2,849 Views)
Not sure what you are trying to acomplish, but if you put the expess VI on the block diagram you can right-click on it and select 'Open Front Panel'.  Say 'yes' when it askes if you want to convert it, then it becomes a sub-vi with a front panel and block diagram you can edit.  Basically this replaces the 'Configuration Dialog Box'.
(2,842 Views)
The configuration dialog box is a another different VI respect the SubVi you put in your block diagram. What I need is edit the VI you can see in the attached picture.
(2,830 Views)
