Edit a particular element in a data base table
Mike i didnt specify the sizes
kavi
Message 31 of 52
(1,466 Views)
Hi kavi,
do you mean an array of names and marks? Or do you want to write a 2d Array into one cell?
Mike
Message 32 of 52
(1,465 Views)
Hi kavi,
you see it, if you change to the design view.
Mike
Message 33 of 52
(1,464 Views)
i automatically set to 4 and 2 for names and marks.
kavi
Message 34 of 52
(1,461 Views)
it automatically sets to 4 and 2
kavi
Message 35 of 52
(1,459 Views)
U can see in the picture that i insert the 2 D array Data using for loop.My question is it possible with out for loop ie. directly wire it in to the the insert DB tool?
kavi
Message 36 of 52
(1,455 Views)
Hi kavi,
i don't know if the insert command can also insert more than one dataset at ones. Where is the problem with the loop?
Mike
Message 37 of 52
(1,452 Views)
No problem its working good.just i want to know without loop is possible.
kavi
Message 38 of 52
(1,450 Views)
Hi
Is there is any option to find if an database file eg.sample.mdb  exist or not as like check if file exist or not function?
kavi
Message 39 of 52
(1,446 Views)
anybody has answer for my question?
kavi
Message 40 of 52
(1,444 Views)
