Edit a particular element in a data base table
Hi I use database toolkits .I created  tadle as shown below with DB Tools Insert data vi.
a
a
Name Marks
kav 88
ani 56
ayy 90
sug 89
jey 97
I want to edit the name ayy and the mark corresponding to the name .can anyone give me a solution for this
kavi
Message 1 of 52
(2,956 Views)
May be you have to use update command with a criteria to update the name.
Message Edited by Ranji on 06-25-2009 02:11 AM
Message 2 of 52
(2,941 Views)
Hi karpaga,
you should use the update command.
Mike
Message Edited by MikeS81 on 06-25-2009 09:13 AM
Message 3 of 52
(2,938 Views)
Thanku all
i will try and come back to u
kavi
Message 4 of 52
(2,934 Views)
I couldn't find a update vi in db tools
kavi
Message 5 of 52
(2,933 Views)
Hi kavi,
use the "DB Tools Execute Query" function with this SQL query:
UPDATE <tablename> SET name="new" WHERE ID=50
You have to close the recordset refnum with the "DB Tools Free object" function.
Mike
Message Edited by MikeS81 on 06-25-2009 09:41 AM
Message 6 of 52
(2,925 Views)
Hi kavi,
in your case the Update command should be like this:
UPDATE a SET Name="kavi",Marks=101 WHERE Name="ayy"
Mike
Message 7 of 52
(2,916 Views)
Hi Mike,
-2147217904
NI_Database_API.lvlib:Conn Execute.vi->Example to Update PhoneNumber Labview MDB (8.6).vi<ERR>.  Invalid string: specified field does not exist or contains an unsupported character
I attached the program and the access i used.
kavi
Message 8 of 52
(2,910 Views)
HI mike,
Im waiting for ur reply
kavi
Message 9 of 52
(2,905 Views)
Hi kavi,
the Marks value has to be in quotation marks, because it's also a text.
See the attached example.
Mike
Message 10 of 52
(2,886 Views)
