Edit Tree Control Question, specific cells
I have a question about editing Tree Controls.
I have played around witht he properties and thus far have not figured it out. This is what I am trying to do:
I have a tree control with multiple columns.
The columns are basically: Name, Description, Value 1, Value 2
What I want to do is be able to select either Value 1 and Value 2 and edit them individually in each row.
I DO NOT want to be able to edit Name and Description.
What I have been able to do thus far is make the table editable, and whenever I get the active cell string no matter cell I click in always returns the value of the first column.
I got around this issue by making my value changes by calling a popup box and edit the values, but I would much rather simplify it by editing the tree.
I cannot provide my actual code but if it helps I can make a facsimile example...
Veni Vidi Duci
Message 1 of 9
(5,761 Views)
Accepted by DB_IQ
Here is a suggestion :
- turn of the cell editing on the tree
- when the user double clics on a cell, if the column index is 2 or 3 then set the edit position to the appropriate cell
see this : (in this example I'm not filtering the column index, but I'm sure you'll be able to add this feature)
Epictetus
Antoine Chalons
Message 2 of 9
(5,752 Views)
Can you attach the code you are working on?
I think you can create the behavior you want to have by using event-driven programming....
Norbert
EDIT: @TiTiou: Writing ActiveItemTag will throw an error when no item tag is present (note: "" is a valid tag!). So either the tree must hide all non-existant items or you have to implement proper error handling.
Norbert
Expert: Geometry
Message 3 of 9
(5,750 Views)
Here is an example, with the fix in place 🙂
I knew there  was a way to do it but I was missing a key piece, which I see now.
Thank you.
Veni Vidi Duci
Message 4 of 9
(5,723 Views)
@ Norbert_B :
error handling?
Never heard of that, what is it?
Epictetus
Antoine Chalons
Message 5 of 9
(5,719 Views)
Cool!
Trees are great, but not always easy to use!
What does the Duci means in Veni Vidi Duci?
Epictetus
Antoine Chalons
Message 6 of 9
(5,716 Views)
My undestanding is it means "I Came, I Saw, I Calculated"
Veni Vidi Duci
Message 7 of 9
(5,709 Views)
@TiTou wrote:
@ Norbert_B :
error handling?
Sorry for me just picking up strange buzzwords.... don't know either
Norbert
Expert: Geometry
Message 8 of 9
(5,701 Views)
One last question:
I can double click on a tree item to change the limit in column 2 and 3, as shown in my example.
But I also have a child item in the tree, with the expand and hide option.
When I double click on column indexes 2 and 3 the cell becomes editable but the child items are either expanded and hiddedn at the same time since the double click was used.
Is there a way to disable that? It's very annoying.
Veni Vidi Duci
Message 9 of 9
(5,672 Views)
