Is there an easy way to modify the runtime popup menus for front panel objects (like graphs, for example)? I'd like to remove some options that I don't want users to pick and add some new ones of my own. The only way I could think of to do this is to capture mouse down events and then make my own menu, duplicating the actions of any items I'd like to keep, which seems like a painful work around.
If the answer is "not now," is there any plan to add this ability to future versions?
Platform independent popup menus can also be realized using pure G.
Try
the attached example (LabVIEW 7.1, but would work in older versions
too).
My simple example so far does not support nested menus but there
are examples for that, too.
See, e.g., the discussion at the
OpenG-forum:
