Edit Map Constant and Set Constant
Collections is a great feature recently added to LabVIEW. However there are simple practical questions. Probably I am too bad internet searcher, so please answer.
Map Constant or Set constant contain no data when placed in BD from palette. However, data-containing indicator can be converted to data-containing constant. Thus constant can contain data.
I cannot find a way to edit such a constant directly in BD. The values are not accessible with any tool. Please advise how Map Constants and Set Constants can be edited?
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
(5,288 Views)
Accepted by topic author _Y_
You can't.
See this idea "Allow-editing-of-map-and-set-constants" for a discussion and some workarounds and ideas.
Main problem is the design of an interface to facilitate the editing. So if you have ideas about that (or a solution), post it there.
(5,262 Views)
, thank you for fast answer. 😪
(5,247 Views)
Sorry is was bad news.
(5,236 Views)
Download this editor plug-in to add the ability to edit sets/maps in IDE. Works in all LV versions that have sets and maps.
https://forums.ni.com/t5/LabVIEW-Shortcut-Menu-Plug-Ins/Edit-A-Set-Value-llb-Edit-A-Map-Value-llb/ta...
(2,051 Views)
