Edge detection in HDL Node
You said that you just want any VHDL code inside the HDL node to accept signals coming from a push button. The code on my previous post does exactly that, just put the node in a loop. What else do you need help with? Specifying a clock signal on your VHDL code? If you want to make the code sequential (work with a clock), I don't think we can be of great help with that, as our VHDL knowledge is limited, and we don't officially support it.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
Message 11 of 13
(978 Views)
I know this fact. I too have very limited knowledge of VHDL. Anyways can you just post me the code plus VI?. And thank you for your cooperation, really appreciate it 🙂
Message 12 of 13
(973 Views)
Accepted by NapDynamite
You're welcome, but the VHDL code I used is back in Post #9, and my VI is not going to do you any good, as the IP Integration Node didn't exist back in LabVIEW 8.6 - just the HDL Integration node did. But here it goes anyway. I also attached the simulation files.
Remember to mark the question as solved and give the appropriate kudos 😉
Daniel REDS
RF Systems Engineer
Help us grow.
Message 13 of 13
(960 Views)
