Edge Detection Help
Hello Friends,
I have a little problem, would be great if someone can help me solving it.
I have an Edge detection VI which gives the number of edges of the input signal.
But I would like if edge detection was 0 for the last 10 seconds, it gives me an Output true or false.
True if the edge detection = 0 for last 10 seconds
False if edge detection , not eqaul to 0 for last 10 seconds.
Thank you,
Kind Regards,
Akash
(2,607 Views)
Accepted by Raj_Raj
The Elapsed Time express VI can be configured to let you know if some amount of time has occured.  You can set this to 10 seconds, and force a reset, if a transition was detected.  Do this inside a while loop that you check every once in a while.
(2,536 Views)
