EXPORT GRAPH IMAGE AND TO BE SAVED(IMAGE, NOT DATA) IN AN EXCEL FILE CERTAIN POSITION
I have generated a LV XY graph, and I want to export the xy graph image(not the data) into an excel file, that means the image will be embedded into the excel file. how can I do that?
also, may I also assign a row and colum position number in the excel file to locate the image?
appreciate if someone can help me on this.
(989 Views)
Hi  Powerdou,
For exporting image from LabVIEW to Excel you should use Report Generation Toolkit.
I have attached some links for you to use to understand how you can use that Toolkit.
Append Image to Report VI - NI
This link is from solved form post download the VI and use that in your project.
Regards)
____________________
(839 Views)
