EXE with Parameter in Commandline
Hi there
I want to make a VI an EXE that I can pass a value in the command line and 2 calculated values ​​get back. How does it work with LabView?
(2,849 Views)
Hi frischro,
reading the commandline parameters is done using a property of the application
(2,843 Views)
Accepted by frischro
You can pass parameters in via the command line, but you can't get values back to the command line.
To be able to pass in the parameters, you need to turn on an advanced setting in the build specification of the executable to accept the command line parameters.  And then you read them with an Application property node.
(2,823 Views)
