EXCEL fails to Launch w/Report Generation Toolkit LV6.1 from a Built Application but works fine in full version
In my developer version, I can generate reports that load up Excel and put the data in. When I build an application, it won't work. I don't get any errors and the code executes, but excel doesn't launch. I have the correct _excelsub.llb file for WindowsXP. It worked fine in Labview 6.0, but the same bld script with the new _excelsub won't work.
(2,611 Views)
You may want to try creating executables of one of the Excel example programs that comes with LabVIEW and see if they exhibit the same behavior. That will tell you if it's your code or something more specific to LabVIEW itself.
J.R. Allen
(2,611 Views)
