ERROR 200220
Yesterday I tried to use the remote panel and somehow I seemed to screw up my system. When I go into my block diagram and go to test the thermal couple I get this error message 200220. Error -200220 occurred at DAQ Assistant
Possible reason(s):
Device identifier is invalid.
Device Specified: SC1Mod1
It's like it doesn't recognize my DAQ modules. All of my scales are gone from the labview custom scaling tab. I go into the Measurement and Automation Explorer and I go to test my CHassis and it says it's not available it's like it lost a configuration file or something. I'm still learning all the in and outs of labview so any help would be appreciated.
Message 1 of 11
(6,290 Views)
You should resetup the configuration in MAX if you are using SCXI.
Message 2 of 11
(6,286 Views)
Being new to Labview How do I go about doing that
Message 3 of 11
(6,282 Views)
Open MAX, Right click Devices and Interfaces, Create New, Add your device
Message 4 of 11
(6,276 Views)
Message 5 of 11
(6,275 Views)
The device it's just not recognizing the global tasks?
Message 6 of 11
(6,261 Views)
You need to give us more information.  What exactly are you experiencing?
Message 7 of 11
(6,257 Views)
When I go to my block diagram and click on my DAQ assistant module, I can pull up the screen that shows what my inputs are for that particular module like thermal couples. When I go to click on the thermal couple to find out the channel, the module isn't there image one shows this. I go into the automation explorer and it shows the modules are there but don't seem to be connected properly in the system. Image two shows this.
Thanks again for your help
Message 8 of 11
(6,251 Views)
Please go through the below procedure and see does it fix the problem.  Keep me in the loop on your process.
http://www.ni.com/support/scxi/scxidaq/hwinst.htm
Message 9 of 11
(6,235 Views)
When I go to create new, the problem that i'm having is that it will reconize it shows up in my device tree under traditional, but my chasis won't show up under my NI-DAQmx. When I go into labview still no channels show up. I am using 4.7 automation explorer labview 7.1 and DAQ assistant.
Thanks in advance
Message 10 of 11
(6,207 Views)
