ai acquire waveform.vi
Recently I receive a code from my senior to read data from DAQ bnc-2090. I have installed DAQmx 9.3 but I cannot run the code due to "cannot load ai acquire waveform.vi." I have find the answers that an old version of DAQ driver is needed. However, TDAQ driver is only suitable for Windows XP/2000, and I use Windows 7. What should I do to solve this problem?  Thank you.
(3,819 Views)
Your BNC-2090 is simply a dumb terminal block. What is the actual DAQ device you have?
(3,815 Views)
Is that "DAQCard-AI-16E-4" ?
(3,811 Views)
You can double check the DAQmx read me but I don't believe that is supported. You would need a different card.
(3,796 Views)
If I still want to use this card, what driver should I install or what change would be done to this function "AI Acquire Waveform" ?
(3,787 Views)
The only driver for that card is traditional DAQ and you've already found out that it is not supported on Windows 7 so why this question?
(3,782 Views)
