ELVIS functions
I am new to the ELVIS system.
I want to use the ELVIS functions provide in the ELVIS CD with Labview 7.1, but seems like some of the sub vi are missing.
And also I tried to run the introduction to ELVIS [link removed], the sub vi are missing also.
Did I miss any library need to be included?
(4,981 Views)
ELVIS functions like DMM, Oscilloscope, Waveform generator etc works only if u r using them with ELVIS Hardware setup i.e. Workstation and prototype board. Let me know if u r using it with ELVIS H/W setup and even after that u r facing problems.
Go to the below mentioned link to know more about ELVIS.
[link removed]
Regards
DC
(4,973 Views)
When I tried to run NI ELVIS.exe from the install CD, all functions work fine.
But when I tried to open the source code functions (function generator oscilloscope) using Labview, and it still says missing subVIs.
 I can't find those missing subVIs anywhere.
(4,956 Views)
Hi Bui,
What subVIs is it asking for? If it is a simple driver or something I can point you to where you can download that. More information would be helpful. Thanks!
Stephanie
(4,947 Views)
When I tried to run Function Generator funtion, it was searching for
NI ELVIS FGEN - initialize.vi
NI ELVIS FGEN - initialize(device).vi
NI ELVIS FGEN - update.vi
NI ELVIS FGEN - close.vi
(4,939 Views)
Have you installed the elvis drivers.
I don't think they're on the cd in the back of the learning manual.
(4,936 Views)
I tried to uninstall ELVIS 2.0 and install ELVIS 3.0, and it is working now.
Thanks for the help.
(4,925 Views)
