Dynamically populate runtime menu for Multicolumn Listbox
I know that it's possible to create a custom Run-Time Shortcut Menu e.g. for a Multicolumn Listbox (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3TOCAY&l=en-US). However I would like to dynamically edit this during run-time. Is this possible? I did some googling but couldn't find an answer. I'm using LabVIEW 2018 32 bit version. Thanks in advance for any help.
(3,151 Views)
Accepted by topic author AndyRR
Hi Andy,
there is a palette with menu functions: use it!
You should get the reference for your menu using the "Menu activation" event…
(3,144 Views)
Thanks a lot. I was looking for that Menu ref of a Muticolumn Listbox, but couldn't find it when i looked for it from the property node.
(3,117 Views)
