Dynamically populate a ring and then select a default value
I have a ring that I clear every time the VI is started and then I dynamically populate the options based on the device connected.
I am trying to select the first option in the ring as the default value. Any ideas on how I can do that?
I tried using an event structure based, where the default value is selected after a 2 second timeout and the other values are selected based on value changes in the ring. However, I do not want to set a time limit on the default value.
(3,048 Views)
Accepted by aashnaw
After updating the options set the value to 0 as shown below. In case you want to fire an event then you can use value (signaling) and it wont need a timeout.
CLD Using LabVIEW since 2013
(3,009 Views)
