Dynamically enabling/disabling items in a custom run-time menu
Hi, is it possible to disable certain items within a customized run-time menu? For instance if I had a daq application with a run-time menu:
File>>Start logging
>>Stop logging
>>Save Test
Whilst the application was logging can I disable the 'Save Test' and 'Start Logging' menu items in the run-time menu but still have the 'Stop Logging' menu item enabled and active?
If this is possible can you tell me how?
Cheers
Bruce
(3,020 Views)
Hi Bruce,
you can use the "Set Menu Item Info" function to do it. If you set the "activate" input to false then the entry is disabled.
Mike
(3,019 Views)
Right, that was easy...
Thanks Mike!
Cheers
Bruce
(3,016 Views)
