Dynamically called vis missing llb vis
From my Main, I'm calling a number of vi's dynamically and it works fine in the development system. However, a few will not come up in my exe but won't give me an error.
I added x10 option to my open vi reference.vi to "Prompt to find missing subvis" and it's missing 2 Modbus vis from the modbus.llb. How/why does this happen and how do I fix it (besides copying the llb into my project - that seems kind of silly)
Thanks in advance.
PaulG.
Retired
(3,760 Views)
Is it possible to "always include" the llb in your build?
Bill
CLD
(Mid-Level minion.)
(3,731 Views)
I would have to copy NI Modbus.llb from vi.lib and save it under my project subdirectory. Then I would have a bunch of conflicts to resolve. And one more copy of the llb to keep track of. I'm trying to avoid that.
PaulG.
Retired
(3,725 Views)
Accepted by PaulG.
How are you referencing the VIs with dynamic calls?  Is it by name, by path, or using a static VI reference?
Static VI references are generally the best way as they should load their dependencies as soon as they're placed on a block diagram.  If you're using names or paths, can you switch?
(3,713 Views)
I went this way. Seems to do the trick. Thanks.
PaulG.
Retired
(3,680 Views)
I'm trying to call VIs dynamically as TestStand does. The VI is ok at the LLB....
Some idea guys?
thanks!
(2,507 Views)
