Dynamic formula
        I have a string for calculating force in a Daq operation, For ex: the string would like   " AI0+0.0254*AI1". I have to create a calculation dynamically for this Daq operation. how to do it?
Message 1 of 9
(6,310 Views)
You could try using the Forumla Node
Message 2 of 9
(6,297 Views)
are you trying to say your formula is not constant and it may vary?
If only inputs are varying then using formula node is ok, but if the operators are going to vary then you will have to write a smart decoder which will identify formula and process as per "BODMAS" rule.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 3 of 9
(6,288 Views)
     yep, the equation varies according to the user definition, sometimes it might be AI0+AI1+AI2*0,005 some thign like this. So , how to do it. If anz exampels pls do post.
Message 4 of 9
(6,284 Views)
I do not have example handy, the only thing I can suggest right now is, write a decoder which will follow BODMAS rule.
search for variables and operators associated with them and then process.
With Regards
Miraz
Message 5 of 9
(6,279 Views)
Other than Decoder, Is there anz other method solving this problem.
Message 6 of 9
(6,266 Views)
Try inserting the variables (AI0,AI1...) in one column of a CSV file and in other column insert formula required.
With Regards
Miraz
Message 7 of 9
(6,262 Views)
I've had success using LabPython.  Here's an example I wrote a long time ago.
Jim
Message 8 of 9
(6,236 Views)
I've never used the LabPython but heard good things.  Also for simple equestions you can use the formula evaluator VIs.  They ship with LabVIEW, but it takes some reading into the documentation to know the format and what functions are supported.  It is under Scripts and Formulas palette under Mathematics.
Message 9 of 9
(6,227 Views)
