Dynamic VI Problems
Yes it will run OK on its own.
Message 11 of 14
(1,136 Views)
Any ideas would be greatly appreciated!
Have you tried this on the "problematic" VI:
Perhaps this before calling the VI?
Not sure if it helps though.
Br,
/Roger
Message 12 of 14
(1,135 Views)
Make sure "Remove Front Panel" is not checked under Source File Settings in the Build Properites.
And can you post the code?
Message 13 of 14
(1,120 Views)
Thanks for all of the suggestions.
I think I may be suffering from some kind of compiler bug. By process of elimination I worked out that there was something on the front panel/block diagram that was causing the problem.
If I create and call test.vi (instead of datalogger.vi) and just have a loop with delay and stop button, the main code will call and display the subvi as expected.
If I copy the block diagram code from datalogger.vi and paste it into test.vi then it stops working.
I have slowly been deleting section of code until it worked and there are two X-Y graphs that seem to be causing me a problem. If I delete one, it still does not work. If I reinstate that graph and delete the other, it does not work. If I delete both of them it works!!!
Very bizarre.
Message 14 of 14
(1,095 Views)
