Dynamic Searching Large 1D String Array Painfully Slow.
Accepted by topic author n2new
Attached is a quick example I threw together using a Map.  It's all based on random 5-character strings.  I have a fixed Map containing 500k of them and then an array containing another 50k of them.
50k lookups in a 500k Map is taking about 65 millisec with For Loop parallelism *disabled*.  When I allow 4 parallel loops it's down to about 35-40 millisec.
Attached is the simple example code, but you'll need LabVIEW 2019 or later for Maps.
LabVIEW 2020 SP1 introduced an NI-supplied binary search of a pre-sorted 1D array.
In prior versions, we resorted to Variant attributes or coding our own binary search.
-Kevin P
Message 21 of 23
(885 Views)
Works Great thank you!
Message 22 of 23
(865 Views)
This works and is about the same speed as the Search sorted vim, new in 2020. I opted for the VIM just because it's small and clean. Thank you!
Message 23 of 23
(864 Views)
