05-11-2021 04:25 AM
I took over the assignment of a previous researcher. He used this pwm amplifier to precisely control the dc motor, and I would like to know what the role of this pwm amplifier is at that time. Is it a role to amplify the signal made by myrio? Before this, signal gnd, +ref in, -ref in pins were connected.
05-11-2021 04:38 AM
Hi Kim,
Yes.
05-11-2021 09:14 AM
Yes, the DC motor current draw is probably too high to be driven directly from the MyRIO.
05-11-2021 11:04 PM
The solution for your problem (keep the motor running) is not PWM, but to set pin state in correct combination. Be aware that code you use is for all-NPN transistors H-Bridge. Your circuit is built with PNP - NPN combination, thus the control is different (NPN transistor is delivering current when saturated while PNP transistor is prohibiting current when saturated).
Try modify your code like this:
if (moveServo == 37)
digitalWrite(resistor1, LOW);
digitalWrite(resistor2, LOW);
digitalWrite(resistor3, HIGH);
digitalWrite(resistor4, HIGH);
else if (moveServo == 39)
digitalWrite(resistor3, LOW);
digitalWrite(resistor4, LOW);
digitalWrite(resistor1, HIGH);
digitalWrite(resistor2, HIGH);
Note that the order is important. Set one pair to LOW first before set the other to HIGH, otherwise you'll short the circuit between function calls.
Note: You can use PWM with analogWrite() function to control motor speed, but you need to slightly modify your circuit: put additional NPN transistor before ground (collector on H-Bridge, emitter on ground), connect it's base with PWM-capable Arduino pin via a limiting resistor.
