Dynamic Generation of clock pulses through PXI e 6556
Hi all, I'm trying to dynamically generate the two phase shifted clock pulses from LabVIEW environment through PXIe 6556 at the clock rate of 25 MHZ, wherein was able to simulate the phase shift between the two clock signals in the LabVIEW environment but the updation was not happening in the oscilloscope whose banndwidth range was about 200MHZ. could someone help me out in this with any suggestions in any firmware updates or change in the hardware setup?
Message 1 of 1
(2,630 Views)
