Dynamic Data (Scan) recording and plotting.
Hello all, I am new to LabView. I want to make a dynamic scan and plot. One will change with time in some step increment and  subsequent output will be recorded and plotted. I am using Group 3 controls as data interface.
I can change input manually and record output and plot. I need a program for automatic scanning, Suggest.
(2,556 Views)
I would recommend that look at the examples that ship with LabVIEW. Start with one of your tasks and get it working then move to the next one. Check in here occasionally and we can help point you in the right direction.
If you look at the top menu bar when you open a new vi and go to the help menu item. You will see LabVIEW examples as one of the options. Look in there to get started.
Tim
GHSP
(2,526 Views)
