cuurent vlaue in Amps from NI 9222
1. I am using Crio 9047 as chasis ,NI9222 for current measuremnt and other module for other measurement
I am measuring acceleration, current, tempreture , voltage , but value of current i am getting on LabVIEW through Create channel Daqmx block and when Monitord it is not proper ,it is in macro Digits though my current is in 30 and 1000 Ampere range.
I am using rogoswki coil as current measurement.
100 millivolts equivalent to 1 Ampere( for range of 3000 ampere)
1 millivolts equivalent to 1 Ampere( for range of 3000 ampere)
2. I can store current data ? or how can i empty my Queue when I am not using it.
My data acqusition  Keeps on running but, when i want to record data i get old data in my file(takes data and record data just below from where it recorded last time though,i am running acquistion at other time)
I did added time out in streams and even in Queue but it did not worked , is it not what it should be doing?
3.Also,i am have 5120 samples per channel and storing These in text file  using Array to spreadsheet string but a emply line at every 5120 samples is getting stored and I am having emplty linees in my file. how to remove that single empty line?
4.I want to chnage the sampling rate, Right now sampling rate is 51,200 though I  have kept 50,000 as rate in sample Clock. how can I chnage the rate?
Below are my VIs
Regards
Vishal
Message 1 of 13
(2,465 Views)
below is the rogswski sensor Picture
Message 2 of 13
(2,452 Views)
I am having the same issue ,
1.getting the a blank line at end of the each samples of strings.
2.also, space get created before first string after getting a sample of string
attached scrrenshot
doing data acquistion and data logging and saving to text file
attached VIs
Regards
Vishal
Message 3 of 13
(2,388 Views)
hello,
Doing data acquistion and data logging and saving to text file
attached scrrenshot
3. also, not getting proper current value from create channel DAQmx , what should be Minimum and maximum value to be set ?
do I have to do custom scaling? I am using rogoswki proble for current measurement,NI 9222 module and LabVIEW 2018 (see the picture)
attached VIs
Regards
Vishal
Message 4 of 13
(2,410 Views)
I want to Change the sample rate but ist not changing  .
when i put rate as 50k it samples at 51.2k S/s ,
when i put rate as 34.13k it samples at 47.8k S/s ,
On board Clock selected , i tried other master frequency eg 13Mhz(cRIO-MAKSIM/13.1072MHzTimebase) and 12Mhz , it Shows error 200414
Why it is not chaging as i want ?
VI attached
Message 5 of 13
(2,345 Views)
Hi vishal,
please stick with your thread instead of creating new ones again and again!
VI attached
Unfortunately you didn't attach any VI this time, so I comment on that older "aq.vi"…
You read several channels from several modules: which modules do you use? Which sample rates do those modules support? Did you read their manuals/specsheets?
You surely talk about error -200414 (mind that minus sign!): did you read the error explanation? It's pretty clear…
Message 6 of 13
(2,330 Views)
Hello Gerd,
Yes , I read the data Sheets of the modules
NI 9231 : 51.2kS/s(max)
NI 9222: 500kS/s(max)
NI 9216:400S/s(max)
NI 9244: 50kS/s(max)
for only NI 9231 Details for sampling rate is given , its in discreate form , a table is given of available rate master timebase frequency.But , These rates are different from the rates i am getting when I am doing data acquistion.
I want to know which rates my program is using?where I can find it?I want to chnage the rate according to me,can I do that?
even what is meant by OnBoard Clock?
when its given for moudule NI 9231 that I can use master frequncy timebase (13Mhz) but, I am not able to chnage it.
Regards
Vishal
Regards
Vishal Kaushik
Message 7 of 13
(2,304 Views)
one more Thing, my source in DAQmx Timing is OnBoard Clock selected
Message 8 of 13
(2,301 Views)
Hi vishal,
what happens when you create one DAQmx task per module?
Message 9 of 13
(2,283 Views)
Hello Gerd,
I created different Tasks for different analog Input and connected each Task one by one and found out that
NI 9222 : works with specified sampling rate
NI 9231 and 9244(acceleration and voltage 😞 gives different rates eg, if specifies set rate to 1k S/s it gives 1477 S/s.
I made a Task which had all the analog inpurts including NI 9216 :  if rate set to 1k it gives 1724 S/s
Please tell how to set requierd sample rate? if ist possible or not?
Regards
Vishal Kaushik
Message 10 of 13
(2,253 Views)
