Dynamic Buttons
@emughal wrote:
But I can draw something up if you would really like. 🙂
Yes, please do. How about a 2D array of clusters?
Message 11 of 33
(2,110 Views)
That toolbar class is a bit difficult for me to comprehend, let alone try to use it in my program. I do not even have my CLAD yet, sigh. I am looking through the examples and have seen some really good ones. I appreciate all the help, and will give ben the accepted solutions. Thanks.
Message 12 of 33
(2,100 Views)
I can make a new topic if necessary, but my question is about SimpleScale.vi in the find examples section. It's simple really, why do the numbers show up twice/thrice on the picture. I am including a screenshot. Thanks. CaptureGraph.PNG
Message 13 of 33
(2,089 Views)
Because you set the precision to 0 decimal digits and there are several markers with the same truncated integer value. Increase the precision to see fractional markers.
Message 14 of 33
(2,086 Views)
Yes alten, I tried that before posting but what if I need them to be without decimals, why are there several markers with the same value. This isn't necessary for what I am doing, its just fmi.
Message 15 of 33
(2,070 Views)
(posting by phone).
I think you can look at the subvi and modify as needed.
Message 16 of 33
(2,067 Views)
Alright I got it working for that particular one.
Another question, I know my min/max, I know the x and y mouse position of the picture. How do I get my min/max to pass in the data, with respect to the the x and y position of the picture.
I know I am supposed to use property nodes bounds and position with the button on the picture, but do I map it out or is there another easier way.
Message 17 of 33
(2,043 Views)
Not sure exactly what you are trying but I will mention...
Using a prototype control that is hidden or in a sub-VI can save a lot of work. Set the hidden control the way you want, Invoke node >>> Get image Then add that to the picture where you want it.
You can loop through using the same control as the proto-type for multiple controls.
If you want to speed it up you can get the image once, cache the image and then over write a part of the background to do updates.
Just sharing what I learned when I wrote those types of applications.
Ben
Message 18 of 33
(2,038 Views)
I set the hidden control on the picture in the front panel, did the invoke node of the button >>Get image. But, what do I add from the invoke node to the picture.
Is there an example which comes to your mind about this? Thanks for the quick response and being patient with a newbie.
Message 19 of 33
(2,027 Views)
Now if you posted some code I would not have to guess at what you really need.
Did you try out the code I included in reply #12 of that Nugget thread?
In that example I used a customized Boolean as the source of my image and inserted the image in the picture at the location where you click.
Does that get you anywhere?
Ben
Message 20 of 33
(2,019 Views)
