Duplicate y scale in wavefrom graph for LV8.0
I'm new to LabView, and I needed to add second y scale to Wavefrom Graph. I know I can righ click the y scale then select Duplicate scale. But the wavefrom alway use the first y scale for plot 1 and 2, is anything I'm missing. Please help, I'm using LV8.0
Ed
(2,979 Views)
Ed, after you duplicate the scale, you need to go into the waveform graph's properties, and configure which plots are associated with which scales.  In the "Plot" tab, you can select which plot, and then down near the bottom of the window, you can choose which X and Y scales that plot is associated with.
(2,977 Views)
Thanks Day
I tried it before and it doesn't let select the y scale I want. Do you know way?
All i want is to plot back the scope wavefrom with different scale.
Ed
(2,973 Views)
Hi Ed,
1) Right click on the Y scale -> Duplicate
2) Right click on the plot legend (on plot whose Y axis association you want to change) and select particular Y scale. Like on attached picture.
Hope it helps
Message Edited by ceties on 10-11-2006 04:13 PM
LV 2011, Win7
(2,965 Views)
It is all i want.
Ed
(2,926 Views)
