12-11-2007 02:51 PM
12-12-2007 10:49 AM - edited 12-12-2007 10:49 AM
What specific error are you receiving?
Aaron R.
Applications Engineering
12-12-2007 10:53 AM
This is the error message I get.
Error 81 occurred at Format Into String (arg 2) in N191X Fetch 2 Channel.vi
12-12-2007 11:35 AM
12-12-2007 11:56 AM - edited 12-12-2007 11:58 AM
12-12-2007 01:53 PM
Randy,
I think the example that you would like to start with is located below. The Fetch Measurement.vi, isn't exactly what you would like to do based upon your posts. To acquire measurements, see the link below. With specific regard to the Fetch Measurement.vi, I have searched extensively to try to locate this specific vi, and I still am unable to do so. Where did you find it specifically?
Download the zip file (Agilent N191X Series)>> extract files>> open Agilent N191X Series folder>> Examples>> Agilent N191X Series Acquire Measurement.vi
12-12-2007 02:06 PM
12-12-2007 03:22 PM - edited 12-12-2007 03:26 PM
Randy,
I have been able to locate the sub vi in question. With regard to Agilent N191X Series Acquire Measurement.vi example you will notice several key items on the front panel. One of particular interest is Combination in this particular box you can measure a single channel, a difference between two channels, or a ratio between those channels. If you want to acquire both single channels(A & B), you can do it sequentially. Which means you could read channel A, then read channel B.
12-12-2007 03:32 PM
12-13-2007 11:50 AM
