Dropdown list from max and min value
I want to create a dropdown menu of natural numbers; I want to input maximum and minimum value and it should show me the list of all natural numbers between these two numbers. My idea was to create an array with for loop and connect it with drop down list. But it seems like my MATLAB logic is useless here and couldn't figure out how even create an array. Any suggestion? Thanks.
Message 1 of 9
(3,096 Views)
So you have three controls:
Two integer controls to enter lower and upper limit
A ring that will fill with items containing all integers in-between. (within reason, you don't want a million entries!). The terms "between" is a bit fuzzy, but I assume you also want to include the limits in the ring.
Should be trivial. Code will fit on a postage stamp. What have you tried?
Message 2 of 9
(3,080 Views)
Accepted by mub.re
Try this:
Don't forget the learning resources listed at the top of the forum.
Message 3 of 9
(3,075 Views)
Thanks! I was trying with for loop and array to connect with combo-box
Message 4 of 9
(3,050 Views)
That sentence has absolutely no information content. 😄
Message 5 of 9
(3,035 Views)
I had no idea, what I was doing😂. Thank you again for uploading the solution
Message 6 of 9
(3,029 Views)
one more question. How can I get the selected number? When I try to extract, it gives me only values(0,1,2..).
Message 7 of 9
(3,007 Views)
Accepted by mub.re
You can us the value to index into the blue array to get the number or you could write the strings&values property instead.
Here are two possibilities:
Message 8 of 9
(2,999 Views)
You are a lifesaver, thanks!
Message 9 of 9
(2,986 Views)
