Drop down box
Issue with the drop down box set to allow for undefined values.   Does not differentiate lower and upper case.
Ex - if i type in lower case c, will not allow an upper case C. Picks up the lower case and overwrites
Work around is to erase the list but defeats purpose of using.
I miss something or going about this the wrong way?
Thankyou
(1,543 Views)
Attach your VI (no pictures, please).  If you are using LabVIEW 2022 (which few of the "active responders" on this Forum have installed so far), please "Save for a Previous Version" (maybe LabVIEW 2019?).  We need to see what, exactly, you are doing.
(1,512 Views)
Hi Sir,
Thankyou for checking .  I isolated everything from the combobox  and issue persisted.
Made own combo box and fix was good enuf.(had to move on to completion, under pressure of time)
Thanks again
(1,473 Views)
