Digital output LabVIEW FPGA
With MyRIO, I want two digital outputs (signals that are mutually inverted because I want to get a larger amplitude). generate 4 pulses with a frequency of 25 KHz every 10 ms. I ordered the program from the picture below. When I look at the digital outputs, I see some transient phenomenon - a peak before the start. maybe who knows why it happened?
thanks
Domen
(2,444 Views)
Maybe overshoot due to fast rise time and load being high-impedance.
Try enabling bandwidth limit on the scope to 20MHz to confirm this assumption.
Santhosh
Soliton Technologies
(2,418 Views)
First of all thanks for the quick reply.
set the bandwidth to 20MHz, but the spike still appears. The peak frequency is approximately 6 MHz (picture in the attachment). The spike appears at the input even if I do not connect any load.
I
(2,391 Views)
Try breaking up the diagram into simple steps.  I have an example below.
(2,374 Views)
(2,361 Views)
Sounds like it may be "faulty design".  If I needed, say, a 10 V "digital pulse" signal, I don't think I'd hook up two TTL Outputs (5 V) and expect to see them peacefully sum (but I'm not an Engineer, electrical or otherwise).  Sounds like a "one-transistor Amplifier" circuit might be needed, to be driven by a single TTL output.  And, of course, you should have an appropriate load included in the circuit.
(2,323 Views)
