Driving 7 segment LEDs using cRIO
I am using cRIO-9101 and I have an analog output module, cRIO-9263. May I know if it is possible to drive a 7 segment LED (which is used as a counter) using the analog output module? Or do I need to get a digital output module such as the cRIO-9474? Also, are the outputs of the digital module based on TTL(transistor to transistor) logic? The chips which I am provided uses TTL to count up/down.
Many thanks!
-Bing
(3,778 Views)
Hi Bing,
I would not recommend using an analog output module to act as a digital output module. Below is an excerpt from the c-RIO 9474 Operating Instructions manual and it sheds more light on the connectivity specification.
"The cRIO-9472/9474 has current sourcing outputs, meaning the DO terminal or pin drives current or applies voltage to the device to which it is connected. You can connect sinking-input devices, such as NPN, open collectors, normally high, IEC negative logic, or other DC devices to the cRIO-9472/9474. A sinking-input device provides a path to ground for current or voltage. Make sure the device you connect to the cRIO-9472/9474 meets the module specifications. Refer to the Specifications section for more information about the output specifications of the module."
Prashanth
(3,759 Views)
Thank you Prashanth for your advice.
(3,750 Views)
