Driver initialization fails when use iivisessionfactory
When I run the attached vi with the top part enabled everything is OK, but if I disable the top part and enable the bottom part then the driver initialization fails and I get a timeout error on the viopen in NI-Spy.   I have also attached the output from NI-Spy showing the results records 126-138 show the successful results and the rest are the unsuccessful results.    Any help would be greatly appreciated
Paul
(2,613 Views)
Hi Paul,
What specific error were you getting when you tried the bottom portion of the VI and from which node does it come from?
Joshua B.
(2,593 Views)
