Drag and drop between multiple instances of an executable
I want to know if there is a special way (not using Windows API) to drag and drop data between multiple instances of a same executable.
I have an application built in LabVIEW, where the main window can open a child window. Each window has a plot control. Between the two windows, a plot data of main window can be copied by drag and drop.
And I open another instance of the same executable. Now there are two executables(A and B).
I want to drag and drop a plot data from the main window of B to the child window of A. But in this case, Drag Enter Event is not fired. I think that the event seems to be fired only inside an executable.
http://digital.ni.com/public.nsf/allkb/AB268878693EF4B586257037004A6725 says that Queue or Semaphore is working only inside an executable. Is drag operation also valid only inside a process?
Message 1 of 1
(2,405 Views)
