Downconvert VI Requests
Hi Ian,
both LV2009 and LV2010 crash when trying to downconvert your VIs...
Message 1321 of 1,444
(1,821 Views)
@smercurio_fc wrote:
All of them crashed. Sorry.
Thank you both for trying - much appreciated. I'll continue to pester the vendor...
All the best,
Ian
Message 1322 of 1,444
(1,819 Views)
Ok,
I'm unlucky...
Thanks for your help!
Bim
Message 1323 of 1,444
(1,814 Views)
Tanks smercurio, so if I want to upconvert my file I need to have a block diaram?
Message 1324 of 1,444
(1,801 Views)
My original codes are in Labview 2011. I want them to be converted to Labview 2010.
David Meacham from NI support told me to post my labview files on the forum.
I hope you can convert them ASAP.
Message 1325 of 1,444
(1,779 Views)
That's correct.
Message 1326 of 1,444
(1,774 Views)
Your code ... needs help. You should really consider refactoring it. Block diagram too big. Unnecessary use of locals. Using string functions to create paths. Using while loops where you should be using for-loops. Using while loops for no reason (i.e., while loops that run for exactly one iteration) ...
Message 1327 of 1,444
(1,769 Views)
hi, these files are developed in LV 2011. I want to open them in 2010. Please down convert the VIs
Message 1328 of 1,444
(1,754 Views)
Can these .net LV2011 VIs be down converted to labview 7.1?  If so, can someone please accomodate me?  I really only need the SMTP side VIs.
Paul
Message 1329 of 1,444
(1,747 Views)
data interleave avg.vi is missing from interleve- Save New.vi.
Otherwise, converted for you
Paul
Message 1330 of 1,444
(1,733 Views)
